How to edit around eyes?
Silhouettecutter
Texas
I like my photo both in B&W and color except for the shadows under her eye. I am new to Light Room. Does anyone have suggestions on how to improve this photo? General critique is welcome as well.
Thank you .
Pam
Lightroom doesn't have the tool I would use - the Patch tool - but Photoshop has it.
Edits around the eyes and on the eye itself require using selection tools quite a bit more precise than any tools Lr offers.
Which is in part why Adobe's Photography subscription includes both Lr and Ps. The two were always intended to used together.
As far as general critique using some fill light from the close to the camera position or a bit further right, reflected or flash, would have delivered a more flattering and pleasing lighting ratio while also eliminating the shadow(s) you now want to edit.
Pose wise I would have had her lower her chin about about 2 inches.
I would also suggest the white balance be adjusted.
I used the Healing Brush on Lightroom, and did three, small overlapping circles on the eye camera right, and two or three VERY small circles on the eye that is camera left. Here is what the Lightroom Healing Brush applied to the under-eye patch looks like, in your original color toning, but with a tiny bit of shadow-lightening added by me, and then the same eye touch-up but in a B&W version. Under-eye circles or skin darkening are one of the single biggest issues we deal with in portraiture.
A few click-and-move actions, using the Healing Brush in Lightroom, will make under-eye darkening much less-visible, as seen above. This is a 20-second fix.
This is an aggressive B&W conversion from the above; the small .JPEG file I worked on was not really big enough to stand up well to this much "pushing", and as a result, the fine details now look a bit less than ideal, like on the highlights of the eye bnd on her hair highlights, but this is one way to envision this portrait, meaning that I was trying to make the tree trunk and the tree bark connection to the subject, without creating a large, detail-free dark area, so I tried to keep the bark's highlighs visible, while letting the majority of the bark disappear.
When it comes to eyes and teeth, they are the most important part of most portraits. In the case of your portrait, the color balance was too warm and need some cooling off. The shadow under the eye was a pretty easy fix with the healing brush in PS. I like to de-saturate the whites of the eyes and teeth and then brighten them just a touch. Beautiful girl.
eye correction by TOM STRAIGHT, on Flickr
This one is with the light room B&W with a green filter. I love the way it brings out the twinkle in her eyes
eye correction green filter by TOM STRAIGHT, on Flickr
Look out for Frequency Separation, Paint on Skin. That should do the trick easy breazy :)
You guys are awesome! Thank you very much. I really need to see how other people edit their photos. Here is the original unedited ,YES I warmed it up way too much. GreyBeard when you talk about the teeth and eyes you lower the saturation and then add white?
Also...I really need to watch some tutorials on Light room. Do you all have any favorites that you would recommend?
Thank you for all your input!
Pam
All of the above are ways to fix this problem but I would suggest to try using a dodge brush first. This will brighten the area and maintain the original detail. If it won't work and looks too unnatural then try one of the other suggestions above.
As you can now see, there are several ways to edit and get good results.
Lowering the saturation to close to zero usually works better than adding white.
Brightening the eyes/teeth can be accomplished in several ways.
A key if you use a selection tool is to save your selections so you can re-use them with different tools.
@Silhouettecutter, I use youtube a lot for this type of stuff. I watch Phlearn, adobe photoshop lightroom channel, scott kelby, matt kloskowski. I have watched plenty of others on there but those are the ones that I like to watch and learn from.
Pam
To brighten up eyes and teeth, in Photoshop I select the white portion of the eyes and teeth, under Image, I select saturation and I turn it down about 60 percent. This will de-emphasize any yellow or redness. I then choose the Brightness control and bump it up just a touch. Don't overdo this as it will look fake.
Lightroom has an Iris Enhance tool that works well for dark eyeballs/irises/pupils: just juse it at low percentages, and do multiple clicks, until you get the hang of it. Lightroom also has a VERY, super-easy-to-use Teeth Whitening feature...try it around 40%, not on full blast. I've also used it on the sclera of eyeballs... This works amazingly well once you get the hang of it! You can go from just slightly whitened, to Entertainment Tonight bleached-white teeth, or anywhere in between.
One of the keys in Lightroom when making adjustments to small areas, like say the teeth, or under the eyball, is to zoom in to 3x or 4x life-size, and in that way you can use the adjustment brushes much more easily. Working on a magnified eyeball, or magnified teeth, is much, much easier and more accurate than working on a small image.
