How to force a studio flash to fire with a D90?
G41.25
Yorkshire
I recently upgraded to a Nikon D90 and have been using it for studio photography (fashion). The camera is connected to one of the lights with a PC synch cable that is plugged into an adaptor on the hotshoe. Mode is set to manual, aperture varies, ISO 200, shutter varies from 1 sec to 1/200th sec.
Problem is that the lights don't always flash. Sometimes I can take 2 or 3 shots of darkness before the flash fires and then I get a perfectly exposed shot. There is no change in ambient lighting etc between shots.
I did a quick google and found someone else reporting exactly the same problem with his D90 and using a similar setup. His last post stated that he had discovered the problem was his 'trigger' - he'd replaced that and not had a problem since. I assume he means the adaptor on the hot shoe. I suppose it could be my adaptor too - just seems a bit of a coincidence.
Anyway, are there any settings that I need to have set that I may not already have? I've not touched the flash settings, I just plugged in the lights, and most of the time they appear to work - just not always!
i never used one of these adapter but its probably a bad adapter or bad cable.
i use some cheap CTR-301p ebay triggers and they work fine fireing 3-4 flash at the same time. i dont remember having problems with misfires.
Faulty cables, adapters & connections are fairly common with flash triggering.
You can get a wireless kit for pretty cheap, or a good one for a bit more.
I'm sorry, but I keep thinking the answer to the question is, "Hold a gun to its head and tell it if it doesn't fire, it will be either shot, or court-martialed."
What if it is the civilian version of the studio flash. No court marshal for civilians?:mrgreen:
If all your cables and connectors seem OK.....
Google < nikon loose hotshoe >
I've seen a few threads in other forums about loose hotshoes on Nikon's as well as Canon's causing problems similar to yours.
I have just found this thread as I am having exactly the same troubles with my D90 and studio lights. Did you manage to get it sorted? any tips? I have a wireless trigger and as far as I know its working fine when I click the trigger itself directly.
