I don't get the "your shutter speed should not be less than the focal length" rule.
That rule assumes handheld, and without IS.
Its usually fairly accurate. I.e. when handholding my 75-300mm lens (no IS), and im zoomed in, I struggle to get a clear image below 1/300.
OTOH, there's people who can hand-hold non-IS 1,000mm lenses and shoot at 1/100.........
....while in a canoe.
if there is perfect lighting and they have fast glass, maybe.
But for average joe with no flash, and a cheapo lens, the rule is valid.
What's perfect lighting have to do with it? 1/100 is 1/100 regardless of the lighting.
And what's fast glass got to do with it? 1/100 is 1/100 regardless of the aperture.
Nikon VR explained
The first and most important rule of VR is this: never turn VR on unless it's actually needed.
Rule #2: VR should normally be off if your shutter speed is over 1/500.
Rule #4: If your subject is moving, you still need a shutter speed that will stop that movement.
Rule #5: VR doesn't remove all motion, it only removes camera motion.
Rule #8: You MUST read your lens manual and see what it says about use on tripods.
