Tim Tucker
- Joined
- Mar 23, 2015
- Messages
- 660
- Reaction score
- 579
- Can others edit my Photos
- Photos NOT OK to edit
From the back catalogue taken about 10-12 years ago, just re-scanned.
I've always liked this shot, but am not sure anyone else will as it lacks the punch of "modern digital processing". It was shot into the light on a bright but overcast late afternoon with the Marion & Co Half Plate with the 1910 uncoated Tessar. I loved the almost low key light and the low contrast, the deep soft shadows and the hint of depth in the higher acutance of the reflections.
I have revisited this scene with a Sinar and a more modern lens in higher contrast conditions. But the shot did nothing for me, unlike this one.
It's Lake Vyrnwy in mid Wales. I saw the scene and immediately set up the camera, (half an hour later...), carefully positioned under a tree to shade the lens I still had to deal with the excessive flare from the uncoated lens on an already low contrast scene. Consequently the negative is thinner than I would've liked, but still prints well. The problem with the scans is the contrast boost tends to exaggerate the grain, no matter what resolution you scan at the grain is the same size when viewed at 100%. In the end I had to scan at 6400dpi, de-speckle, apply a mild noise reduction, remove dust spots and scratches (yep, I'm no angel in the darkroom), then resize to 2400dpi to edit.
To me it's peace, tranquility and calm against the almost unchanging cycle of erosion and evolution that will be around a lot longer than the Victorian pumping tower.
But what do y'all think? (It looks a bit darker reduced in size, best viewed full).
