che thanks!! now the question is what sort of a trigger would i require?? I have a trillion questions cause i'm a beginner so kindly bear with me.. TC
You don't need much from a radio trigger set, other than TTL IF you choose to go with a TTL flash.
The YN 565EX TTL flash is a fine flash that works very well. 2 of my 6 speedlights are of this model. I've had and used them for over 3 years so far without a single problem or issue. Here's an Amazon link to it, though there are other places where it can be bought, and I think
ebay is the very least expensive:
Amazon.com : Yongnuo YN-565 EX TTL Flash Speedlite Canon 5D II 7D, 30D, 40D, 50D, 350D, 400D, 450D : On Camera Shoe Mount Flashes : Camera & Photo
To trigger it and keep TTL connectivity, you need a pair of triggers. You'll need one for the camera, and one for each flash. Assuming you're going to start with one flash then, you need two triggers. They are transceivers, which means that either one will work on either the camera end or the flash end.
Amazon has a variety of them, some older models, some newer with screens on them to show you exactly what the settings are, which is handy and not much more expensive. They also work in combination with one another. You can buy individuals units, which is handy if you add another flash later, or pairs, or even groups of triggers in packages. Generally, the more you buy at a time the more you save, though it's not a lot.
All you need to make sure of when picking them out is that they're for a Canon camera, and that they're TTL capable, if you decide to go with TTL, that is.
Have a look at the offerings on Amazon here:
Amazon.com: yongnuo TTL trigger Canon
Beyond those basic electronics, you may very well want a stand or clamp to hold the flash in any position and be able to aim it, you may want to get an umbrella and umbrella holder, or a softbox or scrim diffuser. There are a TON of ways to hold and modify lights to control the output, and for decisions regarding that stuff, what to get and what to use and why, you REALLY need to go through the course at Strobist. It's way too much to cover here.
