Thank you Tim for the very detailed information!
I have found two very similar external hard drives on amazon.
Seagate and
WD
Both have 4+ ratings and have several reviews (good reviews) and both are very similar in price.
I have a macbook pro with 500gb of storage, I currently have half of that storage full of photos, and only have 2.xx gb left!
With any external hard drive, can you pick and choose which files you want backed up? Also with external hard drives do they simply take the files off your computer and save them on the drive? OR just backed up?!
I have to give you a warning from my experiences over the years. I've owned and used several of those little hard drives over the years, and still use one here for other purposes. I've also given several of them away to family who needed them.
The bottom line is that they're not reliable enough on their own to be used as a backup, IMHO. They WILL fail, and I mean a LOT sooner than the more robust internal hard drives that would be placed into bays in the system or into array bays. I VERY recently had a brand new one of the new Seagate's last less than a month, then POOF - done. Amazon replaced it, no problem, even paid for return shipping on the dead one, but the data was gone - the end. Luckily, I don't trust them enough to rely on them, so I didn't actually lose anything I couldn't replace. I've learned my lesson over the years.
My regular backup storage consists of two 4-Bay enclosures each with another single-bay enclosure on top of them. In each of those 10 bays are internal SATA hard drives of 1TB to 4TB each. The left stack of 5 bays is a mirror of the right stack of 5 bays, redundant in every way.
Originally, when I put it together several years ago, they were each 1TB drives. As a hard drive died, it was replaced with a new hard drive, and its mirror in the other bank was used to make a copy. As hard drive capacities grew, I upgraded dead 1TB hard drives to larger capacity drives.
In addition, I have another 4 hard drives in the system unit, besides the operating disk itself, which has a clone up on the shelf of the OS and the base core programs I use, ready to swap out if needed, in case the operating system drive fails or gets clogged up with program crap that slows things down over time.
To answer your specific questions, yes you can pick and choose which files to back up. They just act as another drive with whatever files you put on them, whether that's another copy of the same files you have elsewhere, or the only copy you have, moved from one drive to the other. You can also use them with backup software to make backups that require the software to access the individual files for restoration, if that's what you want to do. They're just another hard drive, just like working with the contents of your current hard drive(s).
