images upload test
NGH
California
dateposted-public
using my Voigtländer Prominent (w/Ultron 50mm)
That worked, now I just need to work out Flickr embedding...
I see a red X above a photo that successfully embedded.
Hmm I tried a couple of things, maybe that was the first attempt that didn't quite work?
So far I have been uploading files but I'd like to embed from Flickr. I followed the instructions here (How to Post Photos to the Forums) but no joy (see above)
What am I doing wrong?
if you use Method A just copy the url provided from Flikr and paste into box here directly, as is. you don't have to add any img tags. should post just like i did above on test.
if you want more granualer just post direct url i am checking but so far no success.
That's what I tried on the other test above; just went into the flickr image and the share button, selected the size then copy/pasted the text.
Then the second attempt was using Method B with the img tags - still no joy
I see what I did wrong, it works now; I was copying the wrong text to start with Embed instead of BBcode!
