Can't upload images
WVBigfooter
Kingwood, WV
For some reason, I can no longer upload images from my Canon EOS Rebel T6 to my Dell Inspiron 5490 PC. I bought an external card reader, but either it doesn't work or that's not the problem. Please help
Howdy and welcome! Can you connect your T6 directly to your computer? If you can do that, there are a couple of ways to transfer the images. If you are storing them as jpeg, then the OS can transfer the images directly from the camera. If your images are in RAW format, you can connect the camera to the PC and navigate to the images on the camera and copy/move them manually. Some post processing software will also copy the images from the camera, for example if you have an Adobe subscription, you can use Adobe Bridge, then you won't have to mess with constantly removing the SD card from the camera.
I can't connect my T6 directly to my PC. What do I need in order to do that?
Thank you for the link. I bought my camera used
You say "no longer", so how were you doing it before your method quit on you ?
I was putting the card in the card reader on my PC
So if the contacts in your card reader don't work, then why not buy an usb adapter. But it appears you solved it. I thought an adapter might be cheaper and there are no wires.
The transfer cable should look like this
