- Joined
- Mar 29, 2016
- Messages
- 16,111
- Reaction score
- 9,552
- Can others edit my Photos
- Photos NOT OK to edit
- Moderator 🛠️
- #1
Found this pretty much on point common sense The Three Camera Specs You Should Stop Obsessing Over in 2025
I guess there are exceptions in every case, but in your particular case...why do you feel the need? What is the final use of your crop? Are you printing big wall size images??? With prints it's about DPI, and it doesn't take as much as you think. For example the 24mp you mentioned produces an image with a resolution of 6000x4000 pixels, with a 150 dpi that will give you a 40x26.6 print with no quality print. Crop your image 50% to say 3000x2000 you're still 20x13 without a significant degradation on quality in the print.IMO Megapixels due matter if you are cropping significantly especially on smaller things like birds. I don't care how much zoom you have in most cases you still require significant cropping. I will take my 45 MP over 24 MP all day long.
Again to each their own, and I don't shoot birds....not with a camera anyhow, but this seems like taking a .22 full automatic bird hunting instead of my trusty 20ga pump, just point and spray, hoping you might get lucky. Again I don't shoot this genre, but if I did my first piece of equipment would be the addition of a long lens capable of bringing me in closer to the target, where I could concentrate on capturing the shot, with bracketing.Now I shoot at 30 FPS
I use a 200-800 zoom lens so I have the reach covered. The reason for so many FPS is to hopefully catch the wings etc in the best possible position. With the EOS R and a 3-5 FPS max often the shot was simply not there. Once you look at the photos of a bird in full flight you realize virtually every single shot has the wings, head, body etc in a totally different position. It gives you amazing flexibility to pick the shot that best captured the moment you were looking for.but if I did my first piece of equipment would be the addition of a long lens capable of bringing me in closer to the target, where I could concentrate on capturing the shot, with bracketing.
Question? It might be the compression/resolution but there is a noticeable softness and significant artifacts around the ducks as in the first one here. Any insight as to why? At 1/2500 shutter I wouldn't think there would be motion blur even with the 200mm focal length indicated, or was this an extreme crop?Case in point I shot these with the EOS R
Your software sucks. I got a much better rendition, using software designed specifically for enlargemnt. Good enlargiing software, doesn’t leave pixelated images, it smooths them out. I ran it, looked at my the xample and got a good looing image. The poster in this case requested no editing of his work so, I’m not going to post. You’ll have to take may word for it.Question? It might be the compression/resolution but there is a noticeable softness and significant artifacts around the ducks as in the first one here. Any insight as to why? At 1/2500 shutter I wouldn't think there would be motion blur even with the 200mm focal length indicated, or was this an extreme crop?
