Brick
- Joined
- Apr 3, 2009
- Messages
- 107
- Reaction score
- 1
- Location
- Arkansas
- Can others edit my Photos
- Photos OK to edit
- Thread Starter 🔹
- #16
can i ask how much yall pay for frames? you mentioned if you can break even on the cost of frames. i have seen that posted before. what is it that makes the frames so expensive? i make my own frames and well i guess that is why i am puzzled by the cost of them. i have never bought a frame other than the cheap 12x16 $4 frames at walmart for show flyers to show in the shop.
Making your own frames is definitely an option, however you need to have some fairly expensive saws (which I don't have), paint, brushes, and you still have the mounting hardware, mat, glass and all the time it takes to assemble all that to consider as well. If you cut your own mats you can save some money but to do a decent job you'll need to spend a few hundred dollars on mat cutting equipment. Also, I used mostly 16x20 images so my frames were 21x29 - can't really find a frame that large at walmart, and definitely not for $4. You can find large frames at Hobby Lobby but even if they're running 50% off you'll pay $18 without the mat. I ended up using frames from IKEA, they're only $20 each including mounting hardware, glass, and mat. The sizes are a little odd but $20 each was definitely the cheapest option I could find without having to do a ton of work myself.
