It helps to understand HOW the meter works in the camera.
You can buy an external hand-held light meter. These are sometimes referred to as "incident" meters because to use such a meter, you hold the meter at your subject's location (not at your camera's location) and it measures the amount of light which lands on the meter (which would presumably be the same amount of light that would land on your subject and that's why you hold it at the subject's location).
The meter in your camera is sometimes referred to as a "reflected" meter because it measures the amount which lands on your subject AND THEN REFLECTS off the subject and ultimately into your camera.
When you think about that, immediately you might become suspicious that some subjects reflect more light than others. If I'm metering the light by pointing my camera at a mostly flat, black, non-reflective surface... my meter isn't going to register very much light. If, on the other hand, I point my camera at a very bright, white, highly-reflective surface... my meter will register an abundance of light. And this would result in two very different meter readings EVEN if both subjects were in identical lighting conditions. The hand-held meter is much more accurate... but may sometimes be impractical (if you're shooting a landscape of some mountains which are miles away, you cannot easily walk all the way back to those mountains to hold the meter up in front of the slopes... then walk all the way back to your camera. The light would have changed by the time you finished all that walking. Reflected meters are certainly far more convenient, but you need to be aware that they can be fooled... particularly if your subject is either especially reflective or especially non-reflective.
If you notice your scene is dominated by things which are likely to fool the meter (mostly black scene or a mostly white scene) then you might want to either (a) reduce the metering area to a "spot" (don't use full matrix metering) and then select an element which is more of a mid-tone reflectivity, or (b) if using any semi-auto mode (Program, Aperture, or Shutter priority modes) then you might want to dial in some exposure compensation. If shooting in manual, you may want to adjust exposure to something other than the "0" point in the middle of your meter (the camera will usually try to bring up dark subjects so you may want to dial the exposure compensation to a negative value. It will try to underexpose white subjects so you may want to dial the exposure compensation to a positive value.)
