funwitha7d
- Joined
- Jan 8, 2015
- Messages
- 518
- Reaction score
- 190
- Location
- New Zealand
- Can others edit my Photos
- Photos OK to edit
it was early evening, natural lighting was good but I could not capture the colour of this flower accurately, any suggestions?
yes, darn it...Did you have auto-WB setting on?
shot is RAW & JPEG, have not tried to adjust flower colour manually, I have photoshop v9 but don't use it much yetSeeing that you used the flash, you would have to set your your WB as 'flash'. Hope you shot in RAW...
thanks yes this is one of my problems, normally set a WB but for some reason did not try to change thisA lot of auto white-balance takes the largest area of colour and considers it as white/grey, even though it is yellow, so you will need to set the white-balance manually to daylight in this occasion, as it`s got it wrong.
John
a cunning plan, will try to get back to the spot and try this, thanksIf you want truly good colors, then it helps to have something in the image that is of a known white or grey value. So in this situation, you could have taken two images with identical exposures, but one of them would include a piece of white paper. Then in post-processing, you could use the WB eyedropper to tell the program that the paper was "white", and carry that setting over to the second image where the paper isn't present.
yes I need to play around with this, its the first time this has really happened but need to get a bit sorted for the futureIf you don't post process to correct the color/WhiteBalance
then your camera may have the features in the menu to make a copy of it and adjust the colors/Whitebalance.
shot in RAW & JPEGshot is RAW & JPEG, have not tried to adjust flower colour manually, I have photoshop v9 but don't use it much yetSeeing that you used the flash, you would have to set your your WB as 'flash'. Hope you shot in RAW...
