Just got Canon SXi but not so impressed with all hyped about it
This has nothing to do with your Harix, but can someone out there please tell me how you can post photos (not a link to a third party) into a thread if you're not a TPF subscriber??
are you shooting in raw or JPEG?
If you want it sharper you may want to do that in PP.
Even though I encourage people to use RAW mode as much as they can (ie all the time ;)) I am hesetant to suggest it until the person has a little ground in editing the shots as RAW and some of its advantages only come to the fore after editing (such as getting better sharpness by using the computer unsharpen mask)
I would say have a good month playing with the camera - drive friends and family made with it :)
find a site to upload your photos and use the url on here to post the image. You can use this button
to enter the url.
Fully Automatic would be JPEG
oh i would have thought that you could chose between the two somewhere in the options.
to op:
adjust the sharpening in your camera if you aren't satisfied.
I think the major problem is the glare from sunlight reflected off the car. other than that i don't see much of an issue.
Click the insert image icon/button, and voila.
It is the button that looks like it has a small mountain on it.
There is absolutely nothing wrong with your camera or lens... you just need to learn how to use it.
to op:
You can when in the manual modes (ap, tv, P, M, and A-Dep) but all the Auto modes are fixed with Jpeg use
if your sony is taking better pics, you;d better send me that XSi, and i'll take a look at it...put it in the glove box of that car and ship to me. ill figure it out. :)
get into those settings and play.
-biscuit-
They are very sharp. Just the depth of field is quite shallow since you used a wide aperture. Hence only objects at the distance you focused at appear un-blurred.
So what should I do to make it better?
Shoot with maximum zoom from farther distance or minimum zoom with closer distance will makes a difference?
Read up on the different Modes, you will want to change the Aperture some what.
Pick up your manual and learn how to use the features!
A low fstop will give you only a certain amount of space in the frame that is "in focus". A high fstop will put everything in the frame in focus (eg f22 or f16). I say just read your manual.
Harix,
The learning curve between a point & shoot camera and an SLR is pretty steep.
You probably got an SLR because you want to take better quality photos, right? It's going to take some time. Truly it's not the camera that takes the photos, its the photographer--the camera is just a tool to help you get what you want.
The focusing problems you seem to be having sound like aperture issues. Are you familiar with what aperture, shutterspeed and ISO are, and their relationship to each other?
I disagree. Learning how to use the features is impossible when you don't know what the features are.
Start here, the 2 sites I found first when I bought my camera.
Digital Camera Help
Shortcourses - Online library of digital photography
When I first bought the camera, the Shortcourses site explained all the features of a manual camera very well. Start with these two sites and within an evening (lots to read in the Shortcourses site) you will understand a bit about shutter, aperture, ISO, metering, focusing, the different modes (S or Tv, A, P, M...) and much more.
After gaining some understanding about what everything is, start shooting. Shoot anything and everything. Don't just go out and take shots of the cars or trees or the normal things. Really get down and look for stuff. Shoot blades of grass, find little clover flowers in the lawn. Take shots of birds in the trees. Photograph the railing of your porch, or the rain downspout from your gutters. My favorite when learning my camera was setting up my kid's colorful little toys.
It doesn't take long if you do a little bit of research and read. It took me about 2-3 months and everything fell into place for me. It happens just like riding a bicycle, you fall on your face a hundred times, then all of a sudden, dad lets go of the bicycle for the last time and off you ride. You can't even remember at that moment on what it was like to not be able to ride that bicycle.
Most of all, have fun with the journey of learning.
Hi gang!
Just got it 5 min ago, install the lens and battery. Took couple of test pictures with fully automatic, but pictures not what I expected. Look like not focus correctly. What should I do? Get a better lens?
Photos Removed
There is nothing wrong with your new camera. The photos are very sharp. I downloaded the photos and looked at them in Zoom browser and found why you feel they are not sharp. First your photos from Zoom Browser.
Ok first, see the red square in each photo. That is the focus point. It is the only focus point that is active. The other black squares are also focus points, but the camera did not use them. Check the focus at the focus point. DEAD ON SHARP. The large black square is the center focus point You can learn to set the camera to use the focus point(s) you want, not the one it wants.
On the first shot you were shooting at 28mm focal length. To fill the frame at 28mm with the vehicle like you did you had to be quite close. Your f-stop was 10, ISO 200 with a 1/200 shutter speed Fairly narrow, however due to you being as close as you were you depth of field was still quite shallow. That is why you have a lot of area that is out of focus. If you were around 5 feet from the vehicle when you took those shots your depth of field would only be in the range of 4 feet total.
The second shot you were shooting at 1/200 shutter speed with an ISO of 400 again with an f-stop of 10 at 32mm focal length. If you were shooting at about 8 feet you depth of field would still be around 4 feet. If you were 10 feet away it would be about 9 feet total. Again that would explain why a lot of the photo is out of focus.
The jump from a P&S to a DSLR can be challenging. First thing to do is read the manual that came with the camera. Learn the basic functions of the camera and how to use them.
Next go to the library or a book store and get a copy of Understanding Exposure by Bryan Peterson. It is a book that every beginning photographer should have. Even if you have been shooting for a while with a P&S when it comes to DSLR's if this is your first you are a beginning photographer, at least in some ways. It will give you a good understanding of Light, Aperture, Shutter Speed, Focal Lengths, and how they are combined to create different looks when shooting a subject.
Hope this helps a bit.
I know this same thing has been said already, but I'm going to say it in a different way in hopes it makes sense.
Your old point and shoot had aperture settings, but they're entirely different than this camera's. If you had taken this shot at f/2.8 on your sony, you'd need to take it at around an f/8 or even an f/11 to get the same look (depth of field) to it. DSLRs are waaay more capable of isolating the subject from the background than a point and shoot.
If you try and take the shot on your new camera in the same way you did your old one, you probably won't be satisfied. But I REALLY think once you become acclimated to your new camera, and start to understand its settings, you'll appreciate it way more than you ever did your old camera.
Best of luck!
BTW, can I have your car? :)
