LEITZ LEICA 111 RANGEFINDER CAMERA 1933 + ACCESSORIES
Baybers
Australia
Up for sale is my vintage street shooter in very good mechanical and optical condition.
Shutter speeds are accurate throughout the range - 1sec to 1/500 plus bulb.
Rangefinder is accurate and clear with a good visible patch.
Curtains are perfect with no marks nor fungus.
Vulcanite covering is perfect.
Strap lugs are worn and probably not to be trusted in the long term.
A small metal plate has been glued to the upper deck to cover four small holes where a retro fitted flash sync had once been installed. The plate has been applied with silicon only and could be replaced with four small matching screws.
General condition is very good for an 82 year old with some minor pitting and wear marks commensurate with age.
There is no play whatsoever in the controls and the shutter release is precise.
ACCESSORIES INCLUDED
1 X Self-timer (APDOO) in perfect condition
1 x Imarect VIOOH universal viewfinder in very good mechanical condition with very slight haze but quite usable. Dials views for 35mm, 50mm, 85mm, 90mm and 135mm lenses and can be adjusted for parallax from 1 meter to infinity
1 x original half leather case in good condition
1 x cable release with Leica ‘nipple’ attachment
1 x metal body cap
