Looking for opinions
The lighting is nice and the water is pretty much spot on. However you could have produced a composition without the fences. And if Photography is in your name, composition is something you should know.
I too, like the walkway/overlook. Because it's different. Different is good, unique. You don't see that often in this type of photo.
Note: I think the image needs to tilt slightly to the left. Look at the upper falls...it's leaning slightly to the right
This one is tricky. If water is shooting out at an angle, it might not appear to be falling vertically when considering alternate viewing points. There is, however, something that could be considered nearly level; the upper pool containing the splash area and calmer area. I would probably level it using that as a guide.
