Magenta color cast help
I'm gradually developing the routine of tidying-up little bits of habitat before i shoot. It's often worth it.You get the result you work for.
Decided not to bother though, with this one...
... The camera was about 2 ft of the ground. I can't get much lower.
Crawl on your belly like a reptile. :lol:
If you're doing a lot of landscapes, I'd suggest a tripod. Mine will lower itself to 4" (10cm) off the ground. This has several benefits, but two are that it provides a steady foundation to reduce/eliminate shake for longer exposures and it slows you down to compose the shot that is worth seeing.
It may have been a ft high. Its a manfrotto Cf tripod that I used. These were 20 - 30 second exposures
Sent from my Droid using Tapatalk
