Minolta XD7 metering preview issue
Morelax
Hello,
I have a particular issue with my Minolta XD7.
The metering preview with LEDs is not available. There is no LEDs lighting up if I press just a little bit the button. LEDs do not light until I release the shutter.
If someone could help me, I would be pleased!
Thank you
webestang64
St. Louis, MO. USA
OP
M
Morelax
Thank you for your answer.
I haven't been clear in my explanation. The shutter release normally. The light meter works properly.
I just can't "pre push" the button to see what the light meter is saying.
You'll see in the video that there's no light until I release the shutter.
cgw
Ontario, Canada
Looks like the lens is stopped down from the supplied video. The half-press action doesn't work with these as I recall because there isn't one. When the meter is switched on, it's on. Am I missing something? Or are you?
OP
M
Morelax
Hello,
Thank you for your answer. The half-press works on these series actually.
I probably have found the reason in the repair guide. I'm supposed to remove the mirror cage. It will be fun...
cgw
Ontario, Canada
What's the state/position of the stop-down button?
OP
M
Morelax
What are you calling the stop-down button?
OP
M
Morelax
Ok. It's in standard position. Like the other one on my second XD7.
What did you think of?
