Mirror 500mm lens. ..
PaulSanderson
Hi guys and gals,
Im a novice to photography and don't know the ins and outs of kit yet, and someone has offered me a 500mm "mirror" lens.
Whats the difference both in image quality and operation between this and a conventional 500mm lens.
Any advice would be appreciated!!
Many thanks...
Sent from my .....
All considerations aside, mirror lenses generally tend to create softer images. They're generally not as sharp as their lensed cousins.
Another issue is the doughnut-shaped bokeh. Many don't care for it.
Mirror lenses are also fixed aperture. 500mm's are usually f/8.......... and that's all you get. Some have the ability to put small ND filters in them, but they tend to be useless. F/8 makes for a dim VF to start with.
IF it is free... go for it! IF they want money.. RUN! lol!
There are quite a few 500mm mirror lenses, some are better than others. so- what 500 mirror lens were you offered, what camera, and how much?
Nikkor 500/8, on film (Stearman and Yellowcrown) and early digital (Geese/Osprey)
Thanks for replies everybody...I was offered a Hanimex (?) 500mm and he said it was fixed to F8.0...he only wanted £55 for it...
...you think it's better to leave it alone and just save for a sigma 500 or something like that...
Cheers once again - its appreciated...
Sent from my ......
That is a very good price, it is a decent lens- probably on par with the third-party 500/8 lenses of the day. You could buy it, and easily sell it for that price if you upgrade later.
"Most likely" the lens is a "T-Mount", meaning it has an adapter on the end that allows use on many cameras. Most of these mirror lenses use a rear-mount filter which MUST be used- it is part of the optical path. Just some things to check, that it is a T-Mount and the rear-mount filter(s) is with it.
Is it weird that I find, what everyone calls ugly bokeh, interesting? Sometimes I feel having a jittery background could add to the feeling of the image. At least when it works with the subject.
Some subjects produce almost NO objectional bokeh when a mirror lens is used...look at Brian V's samples above, and contrast those three scenarios with the one the video shows at the zoo, where bright, grossly over-exposed highlights shining through dark, green shaded foliage created very bright,white (over-exposed,pure,hot white!) doughnuts; a PERFECT example of how to make the mirror lens's bokeh show up in a guaranteed negative manner.
The low contrast that mirror lenses create is not that big of a problem now, in the digital image processing era...it was killer bad on slide-film...but today with clarity and contrast and curves and specialty software that can enhance things to a fare-thee-well with the click of a slider or two...a lens that produces somewhat low contrast is not that big of an issue.
