What time were these shot at?
One trick you can try if you don't have complete shade coverage is putting the model between you and the sun. Then if you can exposure for the face you should end up with a better result. You might have blowouts behind the model, but imho that's okay and you should get interesting lighting around the hair. See Cliff Mautner's outdoor wedding stuff.
#1 is the best of the set above, it just needs a little help in post. I'd fix the WB, increase the brightness (get the eyes white), maybe bump at vibrance a little, and try to recover the highlights on her forehead and shoulder. But the pose is nice and I think you can make it much better in post.
#2-3-4 all have uneven lighting cast on the model. It's distracting. Look at #2...her face is dark, yet body is light; I don't like this.
Try a vertical crop on #4 and fix the WB.
#5 is again a little underexposed, but the subject is at least evenly lit, I think you could fix this in post. What you can't fix is the tree behind her head. Try to frame/pose the image a little more carefully in these situations. If you had taken 1 step to the left and centered her head to the tree I think it would turn out better, but the background is still a bit busy in general.
