1. It's funny that a small thing like not lighting that green background would make a difference like that.
It's not the lighting of the background it's the color combination you chose to highlight. FYI you can make a white background black and a black background pure white or any color you chose just by changing your lights. Check this out even after watching it I didn't believe it. I had to set up the lights and do it before it registered.
I saw where you mentioned a meter. Have you always had an incident meter or did you just get one. For me the incident meter was the turning point from guessing to calculated results. That and a marathon session with one of my wifes wig heads and hair shooting and lighting and changing until I had a basic understanding of light and shadow on a face.
I've had it for a while and use it sporadically. I am trying to get better about using it to check the lighting. (I know shame on me). I know that you can change a white to black and black to white if you have enough lighting and space. It is easier to make the green go black than the white, lol. Thank you for the input.
Looking at them both in full resolution; I prefer the quality of light in #1; the second just seems a bit too high in specularity. Not a lot, but just enough to me too much. That said, I prefer the light positioning in the second. The other issue with the second is that the camera position seems just a bit too low for me. #2 would be the definite winner (IMO) had the light been a closer/softer/less specular.
Thanks John. The key light was the same in both shots, so I will assume that the specularity is being caused by the speedlight that I used for the fill. As for the camera position, I will have to look at that and raise it up a bit. Thank you for the input.
I agree with
@tirediron - I like the lighting better in #2, but with the higher camera position and hair light from #1. I personally prefer a white reflector to a fill light just because I have a hangup on dual catch lights, but I also sometimes struggle with reflector placement for a self portrait. Great progress!
Thank you Adam. I will keep practicing with both of these set-ups. I agree that I would like to have a 3 light set-up to use.
I am trying to get away from the 2 budget (cheap) studio strobes that I have because I am wanting to sell them and get the
Adorama XPLOR 600 Pro. Once I get this, I will be able to use it as a key light, my streaklight 360 as a fill light and the speedlight as a hair light or to light the background, which ever I choose.
The problem that I am having with the studio strobes is that I have them turned down all the way so getting different lighting ratios is a major challenge. They also do not have the bowens mount for modifiers, so I have either a bounce or shoot through umbrella, which is not as soft as the octabox I have.
Again, thank you all for helping me with suggestions and I will continue to work with what I got to be able to solve the problems I have.
