My Grandfather's old barn - interior shots
rlemert
Raleigh, NC
(For an introduction, see my companion "Grandfather's old barn - exterior shots" thread.)
These pictures have generally had a fair amount of post-processing. I typically had to adjust the high and low levels (and sometimes the mid-points) to overcome my exposure problems. Like I said in the other thread, I'm still trying to get consistent with my exposure levels - and this place adds the challenge of having outside light coming in through all the holes into an unlighted interior.
1) These are the milking/feeding stalls in the milking room I commented on in the other thread. The cows would stick their heads into these slots, and the board you see on your left would slide upright to lock the cows in place. They could lower their heads to get to their feed, but they couldn't back out until Grandpa was ready for them to go.
2) This is a little detail shot showing some of how the barn was assembled. That big horizontal beam is just sitting on the plate on the end of the upright piece. The main frame is all pieces carved to fit into each other (see also the next picture), with maybe a wooden peg inserted in a hole to hold them together. You can also see why we don't generally allow people into the barn - I'm actually surprised it's still standing every time I go home.
3) Another construction detail. Notice all the axe-marks from where the trimmed the tree down to the right size. You can also see that they weren't afraid of using nails - they just used them where they might actually do some good.
4) A general interior view. What's left of the hay-loft's floor can just be seen in the lower right. When it was full, bales could be tossed over the side into the cattle stalls. I've had to do a lot of adjustment in post to get this to look this good - and I've cropped out the major openings to the right. I don't know how this would have worked with HDR, but give me a break - I'm just getting used to taking a decent picture in the first place.
These are much better in terms of exposure than the exterior ones. Probably because it's indoors. But you did a good job with your post-processing like you said! Everything looks a little bit nicer if you get it right when you take it, but these are just fine! (:
#2 is still kinda blown out though. Not much you can do...
My favorite is #1, it actually gives me a feeling of home and comfort. Even though I saw how falling apart this looks to be, I would still feel safe in it. I dont know what it is but #1 gives me a feeling of calmness and the feeling that nothing can hurt me.
Great job (:
Very interesting documentation of the early construction. These are the kind of images that help us all to understand that even our ancestors knew how to put things together without concrete, nuts and bolts, etc. Thanks for sharing. I do believe you are right - HDR would probably helped with the interior shots. You might want to try it, it isn't that hard.
Cheers,
WesternGuy
