Just as note on that Vanguard 263AT in regards to hiking and attaching to a backup, consider that it is 4.41lbs and 24.75" tall when folded up (without a head attached.) My Induro AT213 and Photo Clam Pro-42NS combined weigh about 5.1lbs and is a similar height when folded up. I've only put it on my backpack once, and it was a bear. It does have a shoulder strap that can be used with the bag or just the tripod. It's fine for trekking out into the woods a bit, but I'd hesitate to hike for miles with it.
That said, the only thing that made me nervous about the Vanguard was the head attachment screw and some reports of it snapping. If you're well under the weight rating, I wouldn't worry about it. My Canon 7D, with my 70-200mm f/2.8L and Canon 430EX II flash is about 5.4lbs without mounting plates and such. That was too close to the 11lbs rating for my comfort. The Induro AT213 is a little lighter, yet rated for 22lbs, has a 10 year warranty (after registration) and I felt the simpler column would be more stable. The bag it came with is very nice. It is around $140 just for the legs though.
The Vanguard 264AT or Induro AT214 folds up a little smaller thanks to having 4 leg sections, but they also weigh slightly more and more sections generally means less stable; a fair compromise if you need it to pack smaller.
I think those are reasonable general purpose tripods (i.e. OK to take into the woods once in a while), but hiking/packing I think I'd look more at that Induro Adventure series, the Benro Travel Angel series or maybe something from Sirui. I haven't looked at a lot of these myself, but the
Sirui T-005X Aluminum Tripod with C-10 Ball Head looks promising, weighing 2.2lbs with a 8.8lbs capacity and $140. The ballhead supports arca swiss plates and that's a huge plus IMO. Any mounting plates you buy for that *should* fit higher end ball heads and you have FAR more options for plates ('though, they are expensive.)
Ok, really dumb question....if I want to use this as portrait ' angle' , at 4-5' height, does the weight of the camera throw the tripod off balance?
newbie here...
i was on Adorama yesterday and this does look like it is along the lines and $$ I would like.
thanks,
Nancy
The rated carrying capacity is reduced in the articulated/tilted positions. If I recall, that tripod is rated for 15lbs normally, and 11lbs when the column is not vertical. There is a hook on the bottom of the column that can be used to stabilize/balance the tripod.
