Need help choosing the best Canon
cschafe1
Tampa, FL
Well I've narrowed it down to Canon (the other option was Nikon) for my first full size DSLR.
I've been using a Olympus EPL1 for the past 2 years, and I think its time that I upgrade to a full size DSLR. I am just a step or two above a noob, and want a camera with better auto focus, fuller colors, better lowlight, more lenses, and a viewfinder (many wants :mrgreen:). I have narrowed it down to a couple models: XSi, T3, T1i. A nice lady at the local camera store described the T3 as a very basic DSLR, and would most likely be a downgrade from my PEN. Video is not important to me at all, and MP is not a concern as most of my pictures never get printed larger than 8x10.
These all seem to be very comparable models and I am beginning to think that most likely the newest addition is probably the best for me, but any input would be very helpful.
Thank you so much in advance for your advice.
(My Nikon options were D3100, D80, D5000)
Sorry for the addition, but I found this really cool (ie: fun, full of stats, colorful) website, Snapsort.com and all of Canon's DSLRs seem to score very low compared to Nikon's. The more people I talk to seem to tell me the opposite. Is the reason for their low scores because of a bias in snapsort.com's comparisons, or are Nikon's technically (on paper) a better camera?
a lot depends on what your budget is. If you can budget in a used T3, then you can budget a used Nikon D90, which in my opinion is a better option than the D80, D3100, or the D5000. From the Nikon end, the D90 will give you more lens options as it has a built in focus motor. so does the D80. I honestly do not see the Canon t3 as being a "downgrade" from your oly EPL1, but I dont know that much about canon.
You aren't going to make a mistake with either Nikon or Canon. Personally you should get down to the ergonomics of both to see which fits best to your hands. Then figure which brand has the lens you want/need at the cost that will fit in your budget. Then... make your move.
Personally, if I didn't have my Canon I would have bought into the Pentax system. Good Luck with your choice and enjoy.
Read deeply into what is scored and why it scores high or low on snapsort.
WHat is your budget?
Nikon has a 200mm-400mm f/4.
Canon has:
200mm f/1.8
50mm f/1.0
85mm f/1.2
Canon bodies are normally less expensive.
I have been looking at used bodies for under $400.
Is there any advantage to having a built in focus motor other than to used older lenses without AF?
Thanks again for all the help.
Are there no major differences between the XSi, T3, and T1i?
If your going to go with canon I'd find a used 60D or even the 7D. You talked about better auto focus: The T3i (600D) has only 1 cross type focus point in the center whereas the 60D has 9 and 7D has 19!
With your selections I would get the T3. The t1i and xsi are no models three and four versions old. If you could grab a T2i that would be and awesome camera to start with. Better with more room to grow is the 60D. But I know the selection is based on your budget. Purchase the best you can afford when you make your selection. The lenses can come and go, but the body will stick around for a while. Best of luck.
:thumbup::mrgreen:
There are major differences between the T1i and XSi. If you are looking at the T3, how about the T2i?
Canon has:
200mm f/1.8
50mm f/1.0
85mm f/1.2
They're looking for an entry level camera, not L glass. I don't get the point of this post.
Plus, the 50mm f/1 isn't worth getting for the price point, and the 200mm f/1.8 is prohibitively expensive and hard to find.
I would go for a T2i, OP. Or a used 40D.
For $400 you could get a good used Canon 40D or T1i. Both great cameras. Don't place much stock in tests; at any given price point, photos from Canon or Nikon will look exactly the same. Pick the one that feels best in your hand and is easiest to set all the various settings and menu options.
I'd go for the T1i, seen some offers on the internet plus people on this forum have only said good things about it.
