newbie needs help
ralphbrunt
long beach, ca
I have only been shooting in manual for about a month and i find that i really struggle. this first pic is in manual and the 2nd is in TV. i take more bad shots than good and would like some feedback so i can improve. this is my 10 year old daughter..
thanks ralph.
First of all, everyone gets more 'bad' ones than good ones, if by 'bad' you mean not as good as the best ones.
Second, if you are beginning, imo, there is very little reason to try to shoot manual until you learn the elements of composition. This is like learning to build a car before you can drive one.
You know the relationship between shutter speed, aperture and iso, now put it on a suitable mode, like aperture preferred, and enjoy the fun of photography for a while.
In regards these pictures, focus and exposure are decent, the color is a bit flat because of the nature of the light but that is remedied mostly with a bit of sharpening.
I would chop off some of that excess space.
An article I wrote on shooting for beginners Lew Lorton Photography | Shooting in P mode & Why photographers defend their methods
IMG_4784---Copylll.jpg~original
The pose, unfortunately is 'uncooperative teen.'
Is there something about these photos that you don't like and is there a reason for showing both together? The first was taken at ISO 250 and the second at ISO 800, was there a reason you made that change? As Lew noted they are both in focus and the exposures are good. What are you missing that you posted them?
Joe
i am constantly fiddling around with the settings because im really not sure what is going to turn out best. i posted them together to get the feel of what i thought was good (manual) vs what the camera thought was good (tv) the composition of the 2nd where the big rust spots takes away from the main focus?
Lew thanks for the links
OK- first rule. Use as low an iso as you can, consistent with an aperture whose depth of focus is deep enough to cover what you want and a shutter speed that is as fast as you need.
corollary, shutter speed should be at least faster than 1/focal length if using full frame or 1/twice the focal length if using crop frame camera.
why 1- the lower the iso, the better the resolution and the less sensor noise
why 2 - the depth of field (depth in focus) is inversely proportional to the aperture. The wider the aperture (smaller the number) the shallower the depth of field
why 3 - the shutter speed must be fast enough to overcome the speed of the subject and the natural shake of the photographer.
So, if you shoot in aperture preferred, you pick the aperture, and thus the depth of field you want, the camera picks the shutter speed and, if you set the iso to automatic, will use the lowest iso compatible with the limits you set.
Shooting in manual doesn't make your imags better, it's knowledge and skills to manage the camera that does that.
The ISO change between the two photos -- did you do that deliberately or was the camera set to auto ISO?
When you adjust the camera's shutter speed and f/stop in manual mode do you pay attention to the meter display and make those adjustments to zero the meter indicator? In other words are you relying on the camera's internal meter to determine exposure or are you switching to manual so you can modify the exposure?
My camera has manual control available but I almost never use it as I can control the camera adequately while leaving the camera in P mode and it's faster.
When you mention fiddling with the settings are you referring to the exposure settings or other settings as well?
Joe
