Ni-MH Rechargeable Battery
Link Delight Online Shop
Official Vendor
Supporting Vendor
Ni-MH battery is nickel hydrogen ions and synthesis, power reserve of more than 30% of nickel-cadmium batteries, lighter than nickel-cadmium batteries, longer service life, no pollution to the environment. And for the use of rechargeable NiMH battery and lithium battery, battery charge is very particular. Just bought back the battery power is very low or no electricity commonly, charging must be sufficient for the first time.
As for the Ni- MH battery 5, the most annoying is the memory effect, this effect will reduce the battery’s total capacity and the use of time, but as time goes on, less and less stored charge, the battery will consume the more to faster. Therefore, you should try to be all used up before recharge, each charge must be sufficient to power the most full.
When not long time use, remember to remove the batteries from the camera, put it in dry environment. Recommended you put in the battery box, can avoid the battery short circuit. Long-term not use NiMH batteries will deposit in a few months later, nature into a state of "dormancy" and battery life is reduced greatly.
[TABLE="width: 500"]
[TR]
[TD]
4* 1.2V 2500 mAh Ni-MH Rechargeable AA Battery
US$6.39
[/TD]
[TD]
5 x AA Battery Box Hard Plastic Case Storage White
US$0.99
[/TD]
[TD] 4x Ni-MH Rechargeable AA Battery For SpeedLite Flash US$3.49
[/TD]
[/TR]
[/TABLE]
