Nikon D300 ISO
Soto
Carolina, P.R.
Hello Guys,
I've looking for this and I can't find it... I want to know the excact meaning of this ISO settings in the Nikon D300.
Below ISO 200 I get this:
1. L0.3 = ???
2. L0.7 = ???
3. L1.0 = ???
Which is ISO 100 and what are the others?
Thanks guys
L1.0 = 100
L0.7 = 125
Hope that helps
I've been wondering this myself. From what little I could bear to read the manual all I remember is ~used occasionally~
Not good enough. So I looked around and come up with the following from NikonUSA.com
Low-Noise ISO from 200-3200: The D300’s DX-format CMOS sensor with a high signal-to-noise ratio empowers photographers to select from a broad range of ISOs from 200-3200 with exceptional performance at low-noise high ISO settings. Included is an expanded range of options with Lo-1 (ISO 50 equivalent) and Hi-1 (ISO 6400 equivalent).
I'm not sure what the rest are, but iso 50 is something I've been wanting, now I got it.
Why don't they just say ISO 50 straight up?
I dont believe it is actually 50 iso, but emulated or something. Same with 6400 iso.
From what dpreview said about the d300, ISO 50 and 6400 basically has a levels adjustment done in-camera. I'm not sure if that will reduce noise at ISO 50, but it will increase noise at 6400 in the same manner as photoshop would if you lightened it a stop via levels from 3200.
Hey guys thanks... I got the info
ISO L0.3 = ISO160
ISO L0.7 = ISO125
ISO L1.0 = ISO100
Hi
When I had the Nikon D200 this was not there, you just got the ISO 100to 3200 and just go through to get the shots you wanted in taking pictures.
I have seen the D300 in the shop and it is very impressive and I like the new 3inch LCD screen and improve design of the camera with the 6 frame a second and ad the battery handgrip the frame rate increase to 8 FPS. Good to use in wedding or sports.
mike55
