jdag
- Joined
- Sep 27, 2008
- Messages
- 288
- Reaction score
- 7
- Can others edit my Photos
- Photos OK to edit
absolutely, as far as i have read and researched, there are sick glass for the canons.... another main reason why i would like to stick with a nikon is the fact that i have friends that own nikon dslrs... soooo i can borrow their lenses as well if needed.
That's a good reason in my mind to select 1 of the 2 brands too. My son also has Nikon gear, so we do share/swap lenses often.
how do you like your d7000?? and did you ever consider the 300s?? and do you ever think back and wish you would have gone with the d300s?? thank you
As mentioned above, I had the D90 and went to the D7000, and I do consider it a pretty large step forward. I did consider the D300s, but in reading reviews and chats, it seemed clear (to me) that the D7000 had nearly everything I wanted. In fact, many people do consider the D7000 superior to the D300s in the most important areas, including image sensor and ISO performance (not trying to start a fight here!). My assumption is that the camera that will replace the D300s will leapfrog the D7000, but also be about 50% more costly.
The only few features that the D300s had that were tempting to me over the D7000:
7fps over 6fps
The larger body
The fact that the D300s is fully magnesium alloy
Otherwise the D7000 has every other feature I found important.
