Oversized Matting Options?
LittleMike
Utah
I have a 10 shot panorama that I'm looking at producing fairly large (approx. 24" x 65") and am having trouble finding matting options. My employer wants to hang it in his show room (high-end custom cabinetry and moulding shop) to showcase some of the local scenery and possibly start to sell some of my prints from that location. I have always done everything in the framing process from building/custom finishing the frames, to mounting the photo and cutting the mat. The only step I don't personally do is cut the glass, which I order from a local company. The single biggest problem I am having is locating mat board large enough to do some of my panoramas.
Where do you usually order your mats from? In the past, I've usually just bought them as needed from a chain store in town, but they only carry up to 32"x40", as well as being on the expensive side.
Thanks for any help!
grafxman
TPF Supporters
Supporting Member
FL
KmH
In memoriam
Supporting Member
Iowa
Website
kharrodphotography.blogspot.com
painterskip
SW Florida
Website
www.skipdyrda.com
Unless you can find in locally, most places want you to order a case of the oversized matt board. And even at that, it's 40" x 60" usually.
Since you said that you've matted and framed stuff previously, I'd consider covering some sort of substrate with a fabric. I've done this before, but I used matt board and they were no longer than 60". You could find a plastic supply distributor and order a sheet of something like expanded polyurethane, which is relatively cheap and easy to cut. (unlike plexi). The sheets come in something like 50" x 100" and it can be rolled. Then use spray adhesive to adhere the fabric.
Or use something like thin plywood from Lowes or Home Depot. You could even cut a 'mat' out of that and cover with the fabric. I've done that before.
I use Farco Plastics and they have places all over the country.
Good luck
ClickASnap
