P7 CPU Chip
Takeda
Durham, NC
While working for IBM, I developed, and taught a semiconductor (microelectronics) course. One of my "show and tells" was a P7 CPU chip (wafer, and modules). The P7 was developed by IBM in 2009, using a 45nm (nanometer) technology. 45nm is the minimum feature size (poly width) for the chip design. The P7 successor is the P8 CPU.
Here are some photos, that I thought would be of interest. The DOF is extremely shallow in some of the photos, even at f/22.
1 300mm silicon wafer. Red rectangle is one of many P7 CPU chips on the wafer.
2 Closer image of P7 CPU chip.
3 P7 CPU chip size comparison to penny.
4 Magnified edge of P7 CPU chip.
5 Magnified edge of P7 CPU chip.
6 Eye of needle used for size reference. Spherical shapes are solder balls used for I/O, power, and ground connections to chip.
7 Black rectangle is backside of “diced” chip attached to ceramic substrate. Chip solder balls are reflowed to attach chip to ceramic substrate.
8 Edge of ceramic substrate.
9 Bottom of ceramic substrate. Gold pads are for chip connections to socket/card.
10 Top of completed module.
11 Edge of completed module.
12 Bottom of completed module.
The pictures are sort of bland, but the material behind the images are fascinating.
The second picture has a retro videogame feeling to it. When I wouldn't know the context I wouldn't see it as a picture of something 3 dimensional, it's more like a pattern.
I like #5 since you got the depth playing there. I feel like it could be a Nine Inch Nail cover image :-)
Thank you!
A new photo using extension tubes. Eye of a needle for size comparison:
These I think have great potential! The first ones are almost like abstract art. Its just that theyre a bit bland. I would saturate the colors more for one. And maybe you need to try different lighting.
Thank you for your suggestions.
