Photomatix question
Dmitri
End of the line
So I have a 23 image HDR, 1 stop apart. I load the whole thing into photomatix, it aligns, etc etc. A few minutes later, it's ready to go. Yay!
Now - I find there are two or three settings that I like, and want to save the images as TIF to look at later with fresh eyes. The problem is that, once I process it, it's done. I would have to load all 23 images back in again and wait... suckage!
So the question - is there a way to process an image without losing what you've already loaded in, so you can process again with different settings?
I believe if you do a batch conversion it will save an HDR file that you can open later with photomatix and edit to hearts content. Whenever i do a bunch of HDR's I open photomatix, go into batch conversion, and change the settings to what i need. When it is done converting, it will have a few different jpegs, as well as an HDR file that you can open and process different ways
ok, I'll check that out. Never thought of it, thanks!
ok also I found out, in case anyone else needs to do the same, that if you enable "view intermediary 32bit image" you can save that as .HDR file. Mine was disabled.
Cool, thanks for the tip.
