rufus5150
- Joined
- Mar 8, 2008
- Messages
- 1,657
- Reaction score
- 2
- Location
- Austin, Texas
- Can others edit my Photos
- Photos NOT OK to edit
Are you using camera raw to import them?
When you bring them up on ACR, there's a link at the bottom that tells it what format it will be when it opens in photoshop. Click on that blue link and you can set the defaults for that type of import.
(For example, my link says something along the lines of "sRGB IEC61966-21; 8 bit; xxxx by yyyy (xx.xMP); 250 ppi" (where x's and y's and such are replaced by real numbers).
That brings up an interface where you can make all sorts of juicy changes.
If you're not using ACR, I can't help you.
edit: And then I read you don't use camera raw. I do have lightroom, and I'll check but I remember setting light room to actually work in 16 bit when editing...
