Pictures of my son - Help
klotzishere20
WI, U.S.
Had the shutter set at 1/200. Shoot with the 7D, xsync is 250. There a reason for that black towards the bottom?
Just got these monolights two days ago. First attempts with them.
Thanks for any responses
You probably exceeded your x-sync speed. Can you verify your shutter speed?
You had a gobo between the light and the subject.
What is that spike on the lower right edge of the frame?
Are the monolights "X-Sync" compatible? I don't shoot Canon.. so can't help much. Your Exif data does show 1/200 as your shutter speed. Try shooting at 60, 125, etc.. and see if it syncs ok at the lower speeds.
I shoot canon 5DII at 160 otherwise I get the darkening towards the botton too
Thanks everyone. I will try that today.
The spike is actually the cable to the light. I purchased umbrellas not softboxes.
A: shooting to close or over sync speed
B: shooting with attached flash and lens hood on
C: non compatable lights/speed
Were you in between the lights and baby? Could it be the shadow of the shooter?
