Pines and Pond (Color IR)
JTPhotography
South Mississippi
Just playing around with it, slowly getting there. Notice the color shift toward the center. I think that is a mild hot spot that became more severe in post. It is odd because a few shots before this I tested the lens at the sky above and did not notice any problems at this exact setting. I am learning there are lots of unexpected surprises, good and bad, when working in infrared.
That hot spot is distracting; otherwise, a beautiful shot!
Yeah I'm going to tinker with it I think I can eliminate it. BW is an option but the color is striking if you can nail it.
Magnificent photo.
Sent from my iPad using Tapatalk
Pretty cool composition!!! The center color spot...ehhh....yeah, I see it, but I look past it. I think the top of the image, across the sky, might be a tiny bit darker than optimal. But I do like the way you shot this.
Thanks! I'll mess with it and post an update, as well as a BW version.
BW takes care of the hotspot but I do like the color version better.
