If you need a small size camera, then go with S95.
If you like a camera that can change lens, of course go with EP-1.
If physical size is not an issue, personally I will choose the EP-1 simply because of the interchangeable lens and larger sensor with less pixel density.
iPhone 4.0 take a look at my pix all were taken with that and 10-800mm lens
you are annoying.
