Polarizing Filter in Mountains?
William Baroo
FL
Is a polarizing filter a good idea for outdoor photos and videos in mountainous areas? I hope to be in the alps next month.
Very good for removing reflection off of water, making clouds pop, and adding color to autumn leaves and foliage. It's useful if you're talking bright days with no clouds (ie: direct sunlight). You'd have to stack multiple CPLs if you wanted to use them to reduce light to shoot long exposures (say...a river) in daylight. Personally, while I love my CPLs, I don't use them in the mountains or just outdoors. It is either seasonal (fall) or when I am shooting a lot of clouds.
I'm studying up on this. It sort of looks like the glare reduction is the big benefit and the other stuff can be fixed with Photoshop.
Again yes/no/maybe. If you looked at the link I posted, polarizers don't do much if it's overcast, and the maximum effect is when the sun/light is at 90 degrees. That can create problems if the sun is coming in from one side or the other, as it creates an uneven looking sky.
I find square graduated filters in a Conkin style holder work better for landscape. Stacking multiple filters gives infinite adjustment for tricky dynamic range shots.
I've only used polarizer filters in the studio shooting products and art works for reproduction. Never tried them in landscapes and such. Tried them on autos, they did cut the glare off the chrome, but made checkerboard patterns in the windows.
They are a bit tricky to figure out what they will or won't do for you.
Polarization, which saturates colors, often has a great effect. However, don't overdo the polarization setting when shooting leaves and grasses. I find that if I do, it washes out the life of the foliage by blocking all the reflective elements.
Also, be careful when using polarizing filters with wide-angle lenses and the sky. Because these filters operate at maximum when the light is at 90 degrees, you;ll get light and dark areas in the sky when using wide-angle lenses. Wide-angle lenses capture a too-large angle of the sky. So some areas will have no polarization and others maximum. That creates a banding effect. Shoot a smaller section of the sky with a telephoto or normal lens. That will reduce this issue.
I have never experienced this before and shoot quite a few autos in bright sunlight. I wonder if the windows had polarizing coating on them? I see dark/light stripes in my car windows when wearing polarized sunglasses.
A polarizer is only going to cut glare on one surface plane at a time, like a storefront glass and a puddle on the sidewalk. You can dial in one or the other, but not both. You may be able to find a setting where both surfaces get some help, but not fully.
One thing I noticed by accident, wearing polarized sunglasses while shooting through a polarizing filter isn't the best idea. I've just ordered new glasses and told them not to add the anti-glare coating, which is polarizing. Not to be confused with anti-reflective coatings, just anti-glare.
There are an awful lot of recommendations out there to use linear polarizers on mirrorless cameras instead of circular. You can find videos if you're interested. I use circular and have never noticed a problem.
I don't see that being in mountains has any effect on the usefulness of polarisers. They are great tools for any outdoor shots that have (non metallic) reflections, giving the photographer the ability to control the extent of the reflections, either cutting them down or boosting them as the subject demands.
After IR filters they arte my most commonly used filters :)
Bring it, but go easy with it. The higher the altitude, the stronger it’s effect.
Interesting. Do you have a cite? I'd like to know more about it.
Edit:
Found it, thanks @Spirit Vision Photography for the info, I've never heard this before!
Altitude and circular polarizer filters
Going up high? The effects from your circular polarizer filter will seem more significant – polarization becomes 3% stronger for every 1,000' of elevation increase.
I guess that makes sense. As you get higher the angle to the sun changes, air becomes thinner, etc.
Also some good info about using a circular polarizer for wide angle panoramas. This is worth a read.
