Prairie Storm
invisible
Canada
Thanks for looking...
Does the job, as always! Was this taken with an even wider lens than you typically use?
excellent shot. the lighting is wonderful, except maybe the blown out part in the top corners. The tree and house are positioned perfectly. Maybe a step in and angle slightly to the left to get rid of some of that negative space on the right, but otherwise fantastic!
This is a beauty. Love everything about it.
No, it's the same lens (Tokina 11-16 at 16mm on a full-frame camera). Do you notice anything different?
Thanks everybody for your kind comments and feedback!
The building looks distorted and it's not even in the foreground, but I suppose that's not surprising at 16 mm. I guess the distortion just wasn't as obvious in some of the others, or maybe I just didn't notice.
Move over Ansel
"I'm rolling over instead!", he said :)
Good point. I didn't apply any correction for the lens (which I should have, and may still do because I like the photo).
When you finally put out your photo anthology, let me know. I want a copy. :biggrin:
Duly noted :)
Thanks, guys!
Would it be too much to ask about the processing you did on this ?
Honestly, I barely did anything at all. I just converted to B&W, did some dodging on the front of the house, then played a bit with the color-sensitivity sliders, and that was it...
