roadkill
- Joined
- Jan 26, 2008
- Messages
- 392
- Reaction score
- 1
- Location
- Atlanta GA
- Can others edit my Photos
- Photos OK to edit
- Thread Starter 🔹
- #16
Thank you Chris. Well said and extremely informative. Appreciate it.
Well I was only referring to my 50mm macro. (my other primes are not the same) On my 50 If I am taking a close up of just your eye, threw my viewfinder it is exactly where I want it, then when the camera auto focuses the focus ring will slide out close to 3 inches (in some cases) if it locks focus that far out my shot is now too close so I have to back up, Changing my focal length.happy hour, I don't understand. Sorry. If what I understand these folks to be saying is true, when you have a fixed lens like that there is no playing room in regaurds to focus. Am I off track? All I own are 18-55 Nikkor and 70-300 Quantaray
My Asahi 50mm prime does it. It's not alot, but it's definately happening.Helen
Name a prime lens that varies it's focal length that is a prime? I think you may be confusing that the barrel may extend when focusing but this is different from focal length which remains constant.
Prime = Fixed Focal Length
Zoom = Variable Focal Length
what's the point of a prime? Seems like a lot of money to spend (500-3000 dollars) on a lens that you have to physically move your body to get correct and accurate focus.
sharp and fast
Keith...what is sharp and fast about having to reposition yourself everytime you want a new shot?
No, I'm referring to the focal length of the lens.
OK, so what would you call these three current AF Micro-Nikkors: the 60 mm, the 105 mm and the 200 mm? They all achieve their closest focus by shortening their focal length. The focal length cannot be changed independently of the focus setting. There may be other 'prime' lenses with internal focussing that change their focal length while focussing.
There are a number of high-end motion picture prime lenses (eg Zeiss UltraPrime) that change their focal length while focussing. Think about those focus pulls you see in the movies. If the lens had a fixed focal length, you would see a slight zoom effect as the focus was pulled. We call it 'breathing', and good MP lenses should control it, particularly the wide angle lenses.
Best,
Helen
Well, to be fair, not that many macro lenses change their focal length. I have more macro lenses that are true fixed focal length than variable focal length. In the Nikon macro prime line I think that it's only the recent AF Micro-Nikkor lenses that shorten their focal length. It helps them to achieve 1:1 without excessive extension, helps them to autofocus more quickly and improves illumination a little (the f-number is lower at 1:1 than it would be if it had a fixed focal length, for example the AF Micro-Nikkor 60 mm f/2.8 ends up as an f/5 instead of an f/5.6 at 1:1).
I just try to be as accurate as I can be when I post, that's all.
Best,
Helen
