The resolution of your file and the resolution of the printer are two different things. A file is made up of pixels, each pixel is made up of red green and blue data and that one pixel could be any one of 16million different colours (depending on the bitdepth of the image). A printer relies on halftoning a few primary colours to achieve a specific colour. The individual dots laid down can only have the colour of a combination of what ink is available (9 combinations for a 3 colour inkjet). The pixels in your picture need to be small enough so as to not be resolved by your eye. The practical limit for this changes but typically we're talking 300pixels per inch as being a golden standard for photographs which at a normal viewing distance for a 6x4 will not show any pixellation. The dots a printer need to put down are typically an order of magnitude finer. A typical professional grade printer will print 2880 dots per inch. The only time you'll visibly see these is under a microscope. What is critical is that these numbers are needed so that the printer can approximate the 16million possible colours of your pixel by putting various dots on top of each other or next to each other. With this in mind the resolution of the printer has no relation to the resolution of the file. Obviously when you take it to horrendous extremes and print a 1000ppi image and set the printer to lay down 300dpi (draft mode) then obviously the printer will be limiting, but ultimately through interpolation it is practically impossible for printer to be the limiting factor of a photograph. For somethings yes, but not for what we can hope to visually see with the unaided eye. Now to the notion of film "resolution". Film doesn't have resolution. It has grain. It's probably best thought of has halftoning dots again. But the important part is what you're trying to compare. A sheet of photographic film can be cut to arbitrary sizes. This makes it theoretically impossible for anything digital to approach the resolution of film as the sensor can be made arbitrary in size. That said I have yet to see a 100% tac sharp 24mpxl scan of a negative, so one way or the other digital cameras have surpassed film in terms of usable resolution in a small area. This is also taking into account the ideal scenarios for film. ISO800 film would be bested by pretty much every digital camera currently on the market. Most films are bested by many of the cameras in terms of colour quality and accuracy. And EVERY film is bested by digital cameras in terms of linearity due to a lack of reciprocity failure in digital sensors. As for the mechanics of printer... it's capable of dropping 2880 dots per inch. No film in the world has a grain as fine as the dots placed on the paper by the printer. Also a print head has many ink jets on it which mean the digital part of the printer's control system does not need to be able to guide a print head to 1/2880th of an inch. That said if it were required it would just be a case of gearing. I believe you've come into this thread seeking some kind of affirmation that film is better than digital. My personal opinion is that this hasn't been a case for a while now even under ideal situations.
