The Priolite's big draw is the built-in battery pack concept and "cordless" nature. The specifications seem decent, speed-wise.
Priolite MBX500 500W/s Monolight (115-230VAC) 01-0500-02 B&H
I guess it depends on priorities and desires. You could buy MANY more monolights of lower-spec for $3,000, but then you would not own the pair of Priolites. Studio flash is one of those areas where individuals can choose between HIGH-end, medium, medium-high, low-end, and ultra-economy....there's a monolight for EVERY budget.
I personally would rather own FIVE, or SIX 150 Watt-second flashes than TWO, high-specification, expensive, $1,500 lights...I am used to having as many lights as I need...four,five,or six lights, with two 2,400 W-s packs and one 1600 W-s and a trio of 400 W-s packs, plus a 200 W-s, and not worrying about cost because I bought Speedotron, and it's low-cost used and has been around so long it's not trendy at all...
But that idea has passed; it's now much more-fashionable to go with monolights. It's all a matter of cash, priorities, needs, wants, impression, image; I'm more concerned with having 4,5,or 6 lights because I often WANT to have five separate lights, but if a guy needs or wants only TWO, then I suppose it makes sense to look at a two-light system. Studio and location flash is a difficult thing to generalize about...it depends on what YOU WANT. I don't really know about your needs; is 220 full-power flashes per battery charge enough? As I read it, after 220 shots at full, the battery will need to be charged, but it seems like you CAN SHOOT when it's connected to the charger, and on active charging.
