- Joined
- Nov 27, 2011
- Messages
- 7,716
- Reaction score
- 4,577
- Location
- St. Louis
- Can others edit my Photos
- Photos OK to edit
If you don't think there's a visible difference between JPEG and RAW out of the camera, you shouldn't be teaching people about this topic.
Did someone say there's no visible difference between JPEG and raw out of the camera?
JPEG is a processed file. The camera applies a color space, white balance, contrast curve and sharpening to the file as it's recorded. RAW is an unprocessed file. It has no color space, no sharpening and no contrast curve and thus looks different than JPEG right out of the camera.
A raw file doesn't look like anything right out of the camera; there's no way to view it at all without demosaicing it and converting it to an RGB displayable photo and that's processing. You can't see "unprocessed" using raw conversion software. There's no such thing as seeing an unprocessed raw file. Your raw converter applies processing to the raw data simply to be able to display it.
In fact, RAW usually looks flat compared to a JPEG copy.
It does if you're using LR. But that depends entirely on the default processing applied to the raw file by the converter. All raw converters apply basic default processing and they all do it differently. There's no such thing as a universal "unprocessed" tone curve that they all use so you can see the image in some kind of default state. Open the same raw file in five different converters and you'll see five different "unprocessed" versions of it. Which one is the real "unprocessed" version?
LR opens raw files and displays them usually looking flat. Yep. That's a choice made by Adobe engineers and has nothing to do with how an "unprocessed" raw file naturally looks. They don't naturally look like anything until you process them and other software engineers are free to make other choices and they have.
The changes are applied to the RAW file only upon export. The reason RAW may look the same as you review it on the LCD is because it's a JPEG of the RAW information.
duh.... :scratch:
Jay Maisel: "I don't want to look at RAW because RAW looks like s#&!" If you want to argue, argue with Jay.
I'm not arguing.
Joe
