- Joined
- Nov 27, 2011
- Messages
- 7,714
- Reaction score
- 4,571
- Location
- St. Louis
- Can others edit my Photos
- Photos OK to edit
[snip]...You cannot fix underexposed photos in post-process even if you use RAW. For small amount of exposure correction (-/+ 1 stop) jpeg will do just fine as RAW.Today's digital cameras make 12-bit depth (4096 discrete colors per color channel, as defined by colormetric interpretation of the Bayer array) or 14-bit depth (16,384 discrete colors per color channel, as defined by colormetric interpretation of the Bayer array).
JPEG is limited to an 8-bit depth, or 256 discrete colors per color channel. What happens to the other 3840 or 16,128 discrete colors?
Banding and posterization can result in image gradients because JPEG lacks enough colors to render the gradient without visible steps.
It's not about "fixing" photos it's about processing to an intended outcome when, photographing under natural light conditions, it's not possible to alter the lighting. That's why they invented the zone system back in the good old days. Today we have 14 bit depth captures and you sure can pull up a lot of data from the low end -- a lot more than will be in the camera (sucky algorithm) JPEG.
Here's an example. You'll note from the EXIF data that I dialed in a -.3 EC when I took this photo. I didn't want to blow the highlights in the sky. In the camera JPEG the sucky algorithm sure enough has clipped the red channel and blocked the shadows. This processed by me from the raw file where I had lots of editing headroom:
Here's the camera JPEG full-res if you'd like to demonstrate that it can be adjusted to match.
wetland
I knew what I was doing when I took that photo and I knew what I intended as a final result. I knew I could get it from a raw capture just as surely as I knew that no sucky camera software could do anything with this scene other than crash and burn.
Joe
