"Redemption At The Door..."
X Pro-2
f/1.0
ISO 2500
1/100 Sec.
Zeiss C Sonnar T*50 mm f/1.5 ZM
50 mm Equivalent 75 mm
(Fuji M Mount Adapter)
(Processed In LR, PS, & Color Efex Pro 4)
I just got the lens/adapter tonight & was dying to test it out...
I do have two questions though....the lens is a f/1.5 yet LR indicated the F/stop for the above image to be F/1.0 & I was shooting at 1/125 Sec. yet LR shows 1/100 Sec....
Is that because of the adapter/lens combination or did the camera override me to capture the best possible image considering the poor lights???
Happy Halloween,
Cheers,
Enezdez
It is likely that the adapter is giving incorrect information. If the lens is f/ 1.5 then it would be physically impossible to go to f/1 unless you have some kind of speed booster adapter
@Derrel I did a little bit of research this AM and the adapter is not able to give the correct F/Stop........since the lens does not have electronic contacts....
Thanks...
Does the camera have a non CPU lens encode function, the way Nikon cameras do?
