Remove the battery cover to install a battery grip?
kevinkt
Do I have to remove the battery cover on my camera to install a battery grip? Seems weird that I have to do this.
And secondly if I do have to remove it, how do I do it?
Depends which camera you are talking about.
On my D200's I had to remove the cover since part of the grip went into the battery compartment where the contacts were. On my D700 I don't have to since the electrical contacts are on the camera's bottom plate.
Yep. You probably have to remove it on your camera. At the hinge of the door there will be a spring or a little lever that covers a spring mechanism. Slide it and the cover pops off. Be sure to put in a safe place.
Mine just slides off, and there is a compartment in the actual grip to put the cover in so you don't lose it.
Not on mine (D700). However, there is a rubber cover next to the battery that comes off and the connection thing-a-majigs are there. It locks by screwing onto the tripod mounting hole.
You had to when I had a Canon T1i, as well as with my Canon 5D. Seems pretty normal to me.
With my D40 I did have to remove the battery door. The grip had a slot you could store it in. With my D7000 you do not have to remove the battery door. The disadvantage with the D7000 grip (MB-D11) is that you have to remove the grip to change the body battery. A little weird but that's okay. ;)
It really depends on your camera. I am sure the manual shipped with the camera covers it.
For mine, I remove the door and slide it in the slot on the battery grip.
Yep. On many cameras the battery door just snaps on and off and grips have a place to store the door, or any other part that needs to be removed for the grip to work, like the D300/D300s/D700.
On most (I'd say all, but I can't guarantee that) Nikon dslr's you simply hold the battery cover at a 35 degree angle and pull it out. Super easy. It feels like it's going to break, but it won't. I know for a fact this is how the D40, D80, and D90 are because I've physically done it on those three cameras.
