Removing photo flash from eyes (Not red-eye)
haych
Australia
Hi all,
I have the attached photo I need to get rid of the flash in the eyes. How can I do this? I am not as advanced, I can do red-eye but this is much harder.
Thanks in advance
Haych
Welcome to the forum.
To 'get rid' of something in a photo, you have to replace it with something else. In this case, you would need to replace those white pixels with ones that looked like her eyes. If the spots were smaller and in the centre, you could just 'paint' them black to look like normal pupils...but since the spots are large and look to cover some of the iris as well, it may be much harder to fix.
Is this just an example photo...or is that the photo in question. I ask because it appears to be blurry and low resolution. On one hand, that makes is all that much harder to fix...on the other hand, you you wouldn't have to make it look perfect because the rest of the photo isn't great to begin with.
Hi Big Mike,
The photo is low resolution in the first place as it was taken with an iPhone 4S.
It is the original picture unfortunately. Would you recommend trying to find a photo similar and replace her eyes with the same ones from another picture? Or is there a simpler way?
Thanks for your help.
Haych
That is certainly an option, but it does require that you have a similar photo to pull the eyes from...and it takes a bit of skill with a program like Photoshop CS or Elements to execute the switch and have it look OK.
I won't ask about the specifics...but I assume you have a reason to why you are trying to fix an image that isn't really great quality to start with? The real problem was it was taken with a phone camera and built-in light/flash. So the real solution would be to take a better photo.
I used Photoshop's Clone tool and Brush tool. It took about 90 seconds. Open source (freeware) applications like GIMP.org and Photoscape.org have Layers, Clone and Brush tools.
I started with the eye camera right and used a portion of the iris absent the flash flare as my clone source.
Then I clicked the source over the flare many times until I had approximated the round iris.
Once I had that eye done I used that entire iris as my source and clicked that over the camera left eye.
Next I duplicated that layer, used the Brush tool at an appropriate size, selected black on the color pallet, made a black pupil in each eye and reduced the layer opacity to 50% so the pupils would look more natural.
But now she doesn't have catch lights. ;) :lol:
You are a legend! Thanks mate :)
