Respect!
Jeff G
-Amateur Shutterbug-
Native Californian
I have lots of respect for those of you who can grab those minute details in the Macroverse.
This morning I came across a fresh anthill, and thought I would try and get a shot of an ant, whew....it's tough!
This is the best I came away with, the inset is showing a comparison of size between my thumb and the ant. I think I need bigger ants! ;)
Also gotta have some repect for those little guys lugging around thos enormous payloads.
Just what makes that little old ant
Think he'll move that rubber tree plant
Anyone knows an ant, can't
Move a rubber tree plant
But he's got high hopes, he's got high hopes...
Man, if I could lift like an ant I'd get my yard work done a lot faster!
Are you using any supplemental lighting? If not, I would suggest adding even a single speedlight and diffusing it. That allows you to set your aperture at the best aperture for your lens, then set a reasonable shutter speed, and let the flash add the light.
Thanks all :) It was a spur of the moment thing, will try your suggestion with lighting in the future. :encouragement:
