Sensor size & focal length question
But I'm obviously lacking the language to describe what's inside my head (and, conversely, I've seen three different answers to one question).
Read Helen's post again. You're talking about the projected cone of light coming off the back of the lens. That is not a function of focal length but is a function of the lens design type. Focal length is pragmatically related because with the lens in focus that cone of light will project a circle at the film/sensor plane of a given diameter. If the diagonal of the film/sensor doesn't fit inside that circle you've got a problem or a permanent instagram filter.
The focal length determines at what distance the lens will be from the film/sensor when the lens is focused. One focus distance is unique and particularly important: infinity. At that focus distance the lens will be closest to the film/sensor and the projected circle will be the smallest. The film needs to fit inside the circle at that point.
As the lens is focused on closer and closer subjects it moves away from the film/sensor and so the diameter of the circle at the film plane increases. The angle of that cone of light is staying constant. Think of a flashlight pointed at a wall and start backing up -- the projection circle gets larger while the angle of the cone of light stays the same.
The spread or angle of the cone of light projected from the back of the lens is not the lens's focal length and is not a factor in calculating field of view or angle of view. Those values are used to determine how much of the 360 degree world in front of you the lens is going to record and they require the film/sensor size to make that determination.
We can use lenses on cameras such that the projected circle from the lens at the film/sensor plane is much larger than needed to cover the film/sensor. Once the film/sensor is selected, it's size along with the focal length will determine the angle of view.
Joe
The other side of all this is that a not-full-frame lens lies about its focal كشف تسربات المياه شركة تخزين عفش بالرياض شركة نقل اثاث بالرياض شركة تنظيف فلل بالرياض شركة تخزين عفش بالرياض شركة نقل عفش بالرياض شركة تنظيف واجهات حجر بالرياض شركة تنظيف شقق بالرياض شركة تنظيف بيوت بالرياض شركة جلي بلاط بالرياض شركة تنظيف مسابح بالرياض شركة تنظيف خزانات بالرياض شركة عزل خزانات بالرياض شركة تسليك مجارى بالرياض شركة تنظيف موكيت بالرياض شركة تنظيف منازل بالرياض شركة تنظيف واجهات زجاج بالرياض شركة تنظيف مجالس بالرياض شركة رش مبيدات بالرياض شركة مكافحة حشرات بالرياض شركة تنظيف مساجد بالرياض كشف تسربات المياه شركة تخزين اثاث بالرياض شركة نقل اثاث بالرياض شركة تنظيف فلل بالرياض شركة تخزين عفش بالرياض شركة نقل عفش بالرياض شركة تنظيف واجهات حجر بالرياض شركة نظافة بالرياض شركة تنظيف شقق بالرياض شركة تنظيف بيوت بالرياض شركة جلي بلاط بالرياض شركة تنظيف مسابح بالرياض شركة تنظيف خزانات بالرياض شركة عزل خزانات بالرياض شركة تسليك مجارى بالرياض شركة تنظيف موكيت بالرياض شركة تنظيف منازل بالرياض شركة تنظيف واجهات زجاج بالرياض شركة تنظيف مجالس بالرياض ترميم البيت شركة شفط بيارات بالرياض شركة تنظيف بيوت الشعر بالرياض شركة تنظيف بالرياض عزل الاسطح شركة تنظيف بيارات بالرياض افضل شركة رش مبيدات بالرياض شركة مكافحة حشرات بالرياض تنظيف مساجد بالرياض شركة تنظيف قصور بالرياض شركات صيانة خزانات المياه شركة مكافحة الفئران بالرياض شركة مكافحة النمل الابيض بالرياض شركات مكافحة البق في الرياض كشف تسربات المياه شركة تخزين اثاث بالرياض شركة نقل اثاث بالرياض شركة تنظيف فلل بالرياض شركة تخزين عفش بالرياض شركة نقل عفش بالرياض شركة تنظيف واجهات حجر بالرياض شركة نظافة بالرياض شركة تنظيف شقق بالرياض شركة تنظيف بيوت بالرياض شركة جلي بلاط بالرياض شركة تنظيف مسابح بالرياض شركة تنظيف خزانات بالرياض شركة عزل خزانات بالرياض شركة تسليك مجارى بالرياض شركة تنظيف موكيت بالرياض شركة تنظيف منازل بالرياض شركة تنظيف واجهات زجاج بالرياض شركة تنظيف مجالس بالرياض ترميم المنازل شركة شفط بيارات بالرياض شركة تنظيف بيوت الشعر بالرياض شركة تنظيف بالرياض شركة تنظيف منازل بالرياض عزل الاسطح شركة تنظيف بيارات بالرياض شركة رش مبيدات بالرياض شركة مكافحة حشرات بالرياض شركة تنظيف مساجد بالرياض شركة تنظيف قصور بالرياض شركات صيانة خزانات المياه اصلاح تسربات المياه مؤسسة نظافة بالرياض شركة مكافحة الفئران بالرياض شركة مكافحة النمل الابيض بالرياض شركة نقل وتغليف عفش بالرياض مستودعات لتخزين وحفظ الأثاث بالرياض مكافحة صراصير المنزل مكافحة صراصير المطبخ حل ارتفاع فاتورة المياه شركات العزل الحراري شركات عزل مائي شركة تنظيف الاثاث بالرياض تنظيف انتريهات شركات تنظيف الستائر بالرياض شركة تنظيف كنب بالرياض مكافحة صراصير الخشب شركة مكافحة الصراصير بالرياض نقل اثاث رخيص شركات مكافحة القوارض اسعار نقل العفش بالرياض كشف تسرب المياه الكترونيا تهريب الحمامات والمطابخ مكافحة حشرات الفراش كشف تسربات المياه بدون تكسير كشف تسربات المياه شركة تخزين عفش بالرياض شركة نقل اثاث بالرياض شركة تنظيف فلل بالرياض شركة تخزين عفش بالرياض شركة نقل عفش بالرياض شركة تنظيف واجهات حجر بالرياض شركة نظافة بالرياض شركة تنظيف شقق بالرياض شركة تنظيف بيوت بالرياض شركة جلي بلاط بالرياض شركة تنظيف مسابح بالرياض شركة تنظيف خزانات بالرياض شركة عزل خزانات بالرياض شركة تسليك مجارى بالرياض شركة تنظيف موكيت بالرياض شركة تنظيف منازل بالرياض شركة تنظيف واجهات زجاج بالرياض شركة تنظيف مجالس بالرياض ترميم البيت شركة شفط بيارات بالرياض شركة تنظيف بالرياض عزل الاسطح شركة تنظيف بيارات بالرياض شركة رش مبيدات بالرياض شركة مكافحة حشرات بالرياض شركة تنظيف مساجد بالرياض شركة تنظيف فلل بالرياض [video=youtube;7uae4FdqcYk]https://www.youtube.com/watch?v=_pQQ5TTbxPM"]شركات نقل الاثاث شمال الرياض[/URL] شركة نقل اثاث وسط الرياض شركة نقل اثاث جنوب الرياض شركة نقل اثاث غرب الرياض شركة نقل اثاث غرب الرياض شركة نقل اثاث غرب الرياض شركة نقل اثاث بالرياض الامجاد شركة نقل اثاث بالرياض الصفرات شركة نقل عفش جنوب الرياض شركة نقل عفش شرق الرياض افضل شركة نقل اثاث بالرياض افضل شركة نقل اثاث بالرياض
length in order to remain consistent with honest full-frame lenses.
