- Joined
- May 1, 2008
- Messages
- 25,507
- Reaction score
- 5,113
- Location
- UK - England
- Can others edit my Photos
- Photos OK to edit
- Moderator 🛠️
- #1
The shot processed with CombineZP
http://farm5.static.flickr.com/4015/4291191547_954473af8d_o.jpg
The shot processed with Zerene stacker:
http://farm5.static.flickr.com/4108/5210003510_1998f4893e_b.jpg
Just to show what a different type of software can do - I tried this stacked shot again, this time with Zerene Stacker and its done a fantastic job! Still not quite as ideal as I'd like (it still blows out many of the brighter areas of the shot); but its a massive improvement over CombineZP's attempts with this series of shots. Note that I did alter the white balance between the two shots and this is not a product of the different software approaches (just me not being consistent
Note that shouldn't read that CombineZP is incapable as a focus stacking software choice - its just that sometimes a different approach is needed to get the best possible result. You see a similar pattern with things such as noise reduction programs - each one performing to a high standard, but when faced against specific shots some can outdo the others.
Generally for noise I've not been too worried to use different programs, but because of the more complex and intensive method of focus stacking (ie taking all those shots and finding an insect to stay still) I'm fully prepared to use multiple programs to get the best possible finish.
Interestingly so far Zerene is giving me softer, more noisy and slightly more washed out shots than CombineZP does (excluding the softness on the failed combinezp stack above). Part of this is most likely the settings I'm using, but it appears that whilst CombineZP applies additional sharpening and noise reduction as part of its program Zerene might not be (totally based on guesswork at the moment till I get more into working with Zerene).
