Thank you! I see what you mean about the first two. I'll keep that in mind when trying to do close-up shots.the first two seem too close and in your face to me, while not being quite macro shots.
I like the DOF and leading line on the last shot.
Thanks for the feedback!Agree with Braineack. I like number 3.
First of all--what a very cool find!! I can certainly see what attracted you. Like someone just got tired of all the chopping and LEFT.
I like #3 as well, in terms of showing both the axe and the stump.
But I kinda like the first two as well, though I think I might do something a little different. I'd show you, but your info says photos not ok to edit.
On the first, what if you cropped in and made it almost an abstract? Crop in to just above the three bits of fungi on the left, and then up from the bottom to just a bit below where the axe ends. Then crop the sides so that the wood fills the entire frame. Might be kind neat.
On the second, while I don't like it as much as the first, that incredible old axe IS interesting, and I think I'd really crop in on that, leaving just a bit of the wood that it's cutting into.
Thanks Brian. I'll definitely try next time I pass by. Would you have the angle be directly frontal (facing the cutline) or the side profile (the larger horizontal side so the cut isn't visible)?Agree with sm4him. If you left it like you found it, it may be interesting to get down below the head and shoot up
Thanks Brian. I'll definitely try next time I pass by. Would you have the angle be directly frontal (facing the cutline) or the side profile (the larger horizontal side so the cut isn't visible)?[/QUOTE]Agree with sm4him. If you left it like you found it, it may be interesting to get down below the head and shoot up
