Come on Derrel, brolly is a lot easier to type than
enclosed umbrella. ​
Brolly" is an old British term for a regular umbrella. That's why I do not use the term.
would it help if we added box to it? Brolly box is still shorter.
It might....but the only device I have seen sold labelled as a "brolly box" is nothing more than a cheap, thin-fabric, shoot-through umbrella, with a black backing on it to contain ambient spill. And that gives an entirely,entirely different "look" and characteristic to the light, especially when used with a powerful flash like a studio monolight. When I write the term enclosed umbrella, I am referring to something very specific:
it is a DOUBLE-diffusion umbrella design. What do I mean by double-diffusion? First, the light is bounced into the bowl of the umbrella. Then, that scrambled, diffused, reflected light is once again, diffused by a white, transparent enclosing cover. The effect is very soft, diffused,even light that does not spill all over the immediate shooting area.
The brolly box on the other hand, is a cheap shoot-through umbrella, which produces a central hot-spot of light with weak beam edges, and a fairly specular reflection on facial features like foreheads,cheeks,and noses, and creates that unique, weak, cheap lighting look that shoot-thru umbrellas are infamous for when used with powerful flash units. This is not the same type of lighting device, whatsoever. And the results are entirely different.
Enclosed umbrellas like
the original Photek Softlighter,and the newer Photek Softlighter II, and
the original Lastolite Umbrella Box are all very similar in design and similar in the KIND and the quality of light they produce: controlled, even, not-too-specular, very SOFT, doubly-diffused light. When I say "enclosed umbrella", I am referring to something specific. A very specific
double-diffusion,
100% opaque black-covered, enclosed
UMBRELLA BOX.
Shoot-through umbrellas, and covered-back shoot throughs, aka "
brolly box" devices, are much cheaper, very different devices than enclosed umbrellas or umbrella boxes. You will note that there is not a single "smiley" on "winky" emoticon in any of my posts.
Take a look:
Google Image Result for http://www.usedfilmstudios.com/posts/brolly.jpg
