You used to be able to get a black and white photo paper called "Panalure" from Kodak which was specifically designed for printing color negatives. It was sensitive to all colors, whereas regular black and white paper is insensitive to red.
In fact, graded BW papers are sensitive mostly to blue, a little bit to green, and not at all to red (someone correct me if I'm wrong). And variable contrast papers are coated with two emulsions, one sensitive to blue, and one sensitive to blue and green. The blue-sensitive emulsion makes high-contrast images, while the green-sensitive emulsion makes low-contrast images. The result is that your tones won't be right with graded papers (portions of the image which were cyan (blue-green) will be very dark in the final print, for instance. With VC papers, the effects will be even funkier as parts of the image which were originally yellow will be very high contrast, but portions which were magenta (red + blue) will be low contrast, and the cyan areas will be black. Or so the theory says--again, someone correct me if I'm wrong.
So, the simple answer is that with film, you're usually better off using a black-and-white film for black and white prints. Of course, there are always exceptions.
-JamesD
